ELK LIGHTS 42031 - 2 2 LIGHT OUTDOOR SCONCE IN HAZLENUT BRONZE AND DESIGNER WATER GLASS
The Design Of This Series Draws Its Inspiration From Historic English Manor Houses Throughout The Southern Region. The Traditional Design Of The Cast Aluminum Framework Is Accentuated With A Hazelnut Bronze Finish And Designer Water Glass.
Bulb Type: 60W CAND
Measurements: Item Height: 11Item Width: 36Item Extensions: 13Item Finish: Hazlenut Bronze
Price: 517.40
